Keyless Entry
Khaos
36
Oct 9, 2013
Nashville, Tennessee
When I got my car the keyless remote didn't work (it is the factory remote). Thought it might be the battery so I replaced it, still didn't work. Tried the reprogramming instuctions by connecting pins 1 and 4, doors didn't unlock and lock when flipped from off to acc to off - tried this multiple time, one set of times with a copper wire and the other set of times with a paper clip.
What could be the problem?
If its the receiver how do I know if its bad?
Could it be a fuse?
I dont recall any vehicles in 98 being a "keyless" entry for any vehicle.. so if its on the factory remote.. that means nothing.
Looking at my fuse box display - the only thing that would operate the "keyless" portion is the power window.. and I have an RS model.. so if you have a fuse that is strictly for the power locks - yes you can check the fuse there to see if it is bad - if it looks good you can still try using a different fuse (same amp!) and plug it in and try it..
When you say you changed the battery - are you talking about the remote? How did the board look inside the remote? Any signs of rust or corrosion? If there is a bad connection in the remote itself - yes - you will not be able to operate it by remote.
If these check out to be good and still at a question of wtf? My only other suggestion to you is to take off the interior door panels and check the wiring itself to the keyless entry pop lock within the door itself. Make sure no wires are touching and all wires are connected and are fastened correctly..
Doing this check list should take anyone 2-3 hours to do.. if this doesnt help - you may need to pull the whole system and either replace it or simply go back to key entry
The term keyless means you can enter the car keylessly. Not that there isn't a key hole and that car entry is keyless altogether. A lot of cars came from the factory with keyless entry. Just clearing that up in case you were confused.
The battery I replaced was in the remote and the board was fine. And the doors unlock/lock with the power lock/unlock button so I don't think it's something wrong in the door.
I figure it's the transmitter or a fuse/relay. So the question is, how do you know if the transmitter is bad or is there a fuse/relay that could be bad?
sounds like a bad fob (the little remote thing). go by a dealer and ask them to test your fob. they should do it for free. they will have little box that they point it at and press certain buttons and they will be able to tell if the fob is sending a signal or not.
do you only have the 1 fob?
I'm in the same boar, ish, well mine works but it's on it's last leg and needs replaceing. Dealer still does this?
Ok thanks and yea only 1 fob.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
