keydiver install ?
98GSt_4life
201
Dec 11, 2006
Orlando, Florida
im about to be putting in my stage 3 chip, walbro 255hp, PTE 780cc injectors, and an FPR.
when i install the new eprom ecu and chip which spark plug wires do i swich around, i just want to make sure i get everything right the first time..
Switch #`s 1 & 4 with #`s 2 & 3 (just swap the 2 wires on each coil & put them on the opposite coil). Also, make sure if it`s a 97-99 car, to have Jeff invert the cas. signal in the chip code to correct the injector firing order.
