Key/light warning buzzer
doobycareful
90
Oct 4, 2006
East Highland, Michigan
I tried to hook up my power antenna after doing some reasearch in the fourms and it said to that the power antenna was a white wire with a black stripe so I went and hooked up the same wire and nothing happend, but then I noticed that the wire had silver dots on it and after that the key warning and light warning and dome light did not work anymore. I checked all the fuses and nothing is wrong with them. Is there some other fuses in other places where I dont know about? Can someone please help me its really irritating to do electrical work. :confused:
This is very wierd I went back out there to check it out and i messed a lil bit with the door by opening and closing and it just came back on :)
Yes thank you I have found that out that my door switch is very sensitve if you just touch it a little bit it gos on and off. Probablly need to replace it. Thanx again. I love this web site.:)
