Just started tuning w/ MAFT and logger. HELP!
99gst_racer
Moderator
12,010
1,707
Apr 5, 2003
Coloma, Michigan
I recently installed my new turbo (T04b v-trim), MAFT blow-thru, 650cc injectors, and Key driver chip. I'ma also relativily new to my datalogger.... I cant seem to get my timing curve to even look good, let alone be perfect.
If anyone is very familiar with the MAFT translator, please feel free to chime in. I got the car to idle good and it seems to be driving OK too. It was better on stock injectors though. Here's my log I just took today.
5/17/05-20:11:51 - Obd2
Time,RPM,Timing,O2 1 Bank 1
00:03.56, 1252.0, 13.0, 0.82
00:04.76, 1416.0, 21.0, 0.86
00:05.94, 1400.0, 21.0, 0.58
00:07.13, 2484.0, 23.0, 0.0
00:08.32, 3576.0, 14.0, 0.02
00:09.52, 1576.0, 7.0, 0.9
00:10.71, 3296.0, 9.0, 1.0
00:11.89, 5316.0, 19.0, 0.96
00:13.09, 7708.0, 39.0, 0.6
00:14.27, 5032.0, 16.0, 0.92
00:15.46, 6084.0, 19.0, 0.94
00:16.64, 6980.0, 15.0, 0.94
00:17.84, 5296.0, 35.0, 0.84
00:19.03, 3504.0, 16.0, 0.96
00:20.21, 3572.0, 9.0, 1.0
00:21.39, 2772.0, 9.0, 0.06
00:22.60, 2988.0, 34.0, 0.9
00:23.78, 2896.0, 23.0, 0.0
00:24.96, 2800.0, 23.0, 0.0
00:26.15, 2716.0, 30.0, 0.06
00:27.35, 2692.0, 30.0, 0.78
I'm wondering why at 7708 RPM's, I have a 39 for timing..... And seconds later, at 6980 RPM's, I have a decent number of 15. I am only tuning with the translator, and I'm still learning about it. Can someone knowledgable on tuning please chime in and help me out. Educate Me!!!
OK, here's my 3rd gear pull. Before I did the pull, I made one change to the translator. I change my WOT setting from -25% to -20%. This log looks much better.
5/17/05-23:02:13 - Obd2
00:00.72, 2856.0, 9.0, 0.96
00:01.43, 3016.0, 9.0, 0.98
00:02.14, 3200.0, 8.0, 1.0
00:02.86, 3392.0, 6.0, 0.98
00:03.57, 3640.0, 8.0, 0.96
00:04.28, 3916.0, 10.0, 0.94
00:05.01, 4232.0, 14.0, 0.88
00:05.73, 4516.0, 13.0, 0.9
00:06.44, 4840.0, 13.0, 0.92
00:07.15, 5144.0, 14.0, 0.94
00:07.86, 5452.0, 14.0, 0.94
00:08.57, 5748.0, 16.0, 0.94
00:09.28, 6016.0, 17.0, 0.94
00:10.01, 6264.0, 20.0, 0.94
00:10.72, 6472.0, 19.0, 0.94
00:11.44, 6712.0, 20.0, 0.94
00:12.15, 6904.0, 20.0, 0.94
00:12.86, 7056.0, 17.0, 0.94
00:13.57, 7228.0, 19.0, 0.92
00:14.30, 7368.0, 18.0, 0.94
00:15.01, 5340.0, 19.0, 0.68
00:15.72, 3472.0, 35.0, 0.7
00:16.45, 2012.0, 23.0, 0.0
00:17.15, 1020.0, 13.0, 0.0
00:17.87, 1060.0, 16.0, 0.04
00:18.59, 1180.0, 9.0, 0.08
00:19.29, 1244.0, 11.0, 0.86
What do you think? I just put the 650's in 2 days ago. Until now, I've been running stock injectors and it was running really good actually. I'm only at 12 lbs. right now, but will be turning it up to 20-22 PSI (hopefully) by the end of the week. I just need to increase my tuning skills a little bit before I go cranking up the boost too much.
Hows this log look? What needs to be better? Thanks in advance. :dsm:
CanadianTSi said:
looks like you go a bit lean around 4k, I would add some fuel there.
Forgive me if my questions sound "newbie-ish". I just want to make sure I understand everything correctly. To richin it up around 4K, I would want to make a change to the MID control, right? It is currently set at 30%. What would you recommend changing it to? Thanks for the help.
You can't tune with a stock O2 sensor housing well enough to validate the interpretation of the sensor reading a few volts less then the other rpm ranges. I'd like to see what the log looks like under the guidance of a wideband.
Just make sure you aren't knocking and take the general average of the O2 sensor using the fuel trims to tune conservatively now.
Yeah, you and me both. I'll see if I can get ahold of one within the next 2 weeks.
I have the knock sum gauge where the factory boost gauge is. One of the Keydriver features... Are they at all accurate? I'm not getting any high readings on it......
How should my STFT and LTFT look?
OK, I was just prcticing my holeshots to see where I want my 'selectable launch RPM' set at, and I decided to log one of them. Check this out. (I seperated it where I shifted, 1st through 3rd gears)
5/18/05-19:06:33 - Obd2
Time,STFT,LTFT,RPM,Timing,O2
00:01.18, 0.0, -4.0, 2932.0, 26.0, 0.0
00:02.36, 0.0, -4.0, 1824.0, 5.0, 0.92
00:03.55, 0.0, -4.0, 3044.0, 10.0, 0.98
00:04.76, 0.0, -4.0, 4828.0, 19.0, 0.94
00:05.94, 0.0, -4.0, 7528.0, 39.0, 0.58
00:07.13, 0.0, -4.0, 4852.0, 16.0, 0.94
00:08.31, 0.0, -4.0, 5972.0, 21.0, 0.94
00:09.52, 0.0, -4.0, 6940.0, 22.0, 0.94
00:10.69, 0.0, -4.0, 4720.0, 21.0, 0.86
00:11.88, 0.0, -4.0, 5288.0, 16.0, 0.94
00:13.06, 0.0, -4.0, 5696.0, 19.0, 0.94
00:14.27, 0.0, -4.0, 6084.0, 20.0, 0.94
00:15.44, 0.0, -4.0, 6472.0, 17.0, 0.94
00:16.63, 0.0, -4.0, 6784.0, 18.0, 0.94
00:17.84, 0.0, -4.0, 7056.0, 19.0, 0.94
Whats up with my timing and O2 reading at the end of 1st gear? What would cause it to look so nasty? Also, how do my fuel trims look?
I assume your using a pocket logger. You will only get like 11data points at a time, so only log 3 items, rpm, timing and O2, at a time.
When your trying to get your STFT in line, before you make a change on the MAFT reset your ECU, a 2g compensates rather quickly. I found that I got a better STFT tune this way.
Since you have the keydiver knock indicator, what I would do is just log rpm and timing and eyeball the knock guage as I'm going through the rpms. If it's not knocking then the hell with O2's. It's all in the timing as you go through the rpm's.
Yeah, I'm using the pocketlogger. I usually only do log RPM, Timing, and O2's. I just wanted to see my fuel trims this time around..... (i'm still experiencing with my logger. i've only had it for a couple weeks)
My keydriver knock sum gauge satys at 0 all the time, which I believe is indicating a knock count of 5 (right?).
It's goes like that for the instant when your off the throttle shifting...
As for your fuel trims, check them under idle and while cruising at steady rpms not WOT.
