Just picked up a 2g... questions
jdenicola187
Sep 10, 2009
Rutland, Vermont
96 talon tsi awd
bep 50 trim
750cc
tre stage two trans
act 2600 clutch
What should I do about boost creep/spike?
I want to go external..
whats the difference between the punishment racing 02 housing
with a external wastegate flange
vs.
going with a different exhaust manifold with one on there?
I originally though the wg had to be before the turbo coming off the motor
An external wastegate can either be on the exhaust manifold or the o2 housing. Some may say off the manifold is better but the results will be similar. If you get a manifold with a provision for an external gate it would be wise to get one with the wastegate coming off the collector instead of off just one runner. They will work off one runner but it would be better to come off the collector.
what are the negatives to doing it off the 02 housing?
how about the internal one that there is right now... how do i go about taking
care of it when i go external?
i would do a different exhaust mani but i figured they were way more expensive then the 02 housing from punishment
