JUST missed 12's
xcelr8n
1,854
5
Jan 31, 2003
toronto,
Just got back from the track, was a scorcher outside temps outside were in the low 90's, Im sure track temp was a lil higher, was damn humid to...
Evo3 @20psi, fmic, maft, 650s, 190lph, act2100...
Best of 13.03 @103mph..
I ran 25-30 times, and have 22 slips between 13.0-13.2, all of which with traps above 102 mph, so I was consistent.
Launching with 5500rpm stutterbox managed nothing but 1.75 60' all day long, give or take a hundreth.
We got rained out in the last hour right after the best run I made, I raced back to do another but I was too late...
This car is an absolute blast to launch now... it went sideways every single time :D
SBstar said:
That seems like alot of runs for one evening anyways haha. Good luck next time.
There were about 10 1gs, and only one exploded, so 10% thats not to bad..
my buddies sorta exploded, but we fixed it, so 15% :thumb:
Im thinking this pig needs to loose a lil weight to..
xEM1x said:
I bet your clutch loves you. :p Nice times.
Even more so with the 5500 rpm stutterbox leaving the line with 10-12pounds of boost.
I had no idea it got that hot over in Canada LOL! That 13 flat seems a little slow for your modifications, were you on race gas at all ?
That slip should be high 12s although the 103mph trap is low for a B16G at 20psi.
Nigel, your neglected your...
1. Pre-turbo exhaust leaks.
2. Unknown turbo boost leaks.
3. Tuning finely.
4. A good driver. LOL!
Next time you'll hit the 12s.
Great time! I just ran a 13.0 tonite on my 14b! :) Stock injectors/cams/nothing to tune with etc! It was my first time ever racing at a track :) nice time, You're right, It is REALLY fun , Especially for someone like me that never had done it before :thumb:
Yes, the 13.0 slip has a low trap at only 103, all the other low 13 passes are closer to 105 mph FWIW..
I was using pump Gas, probably 92octane.
Your 60' is pretty good. my best 60' was a 1.813 with shitty tires and stock worn out suspension. But in that run i was able to hit a 12.97 at only 101.88 mph. :D. That was without lifting to shift into third and fourth. Next time try to leave the gas to the floor when shifting.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
