Just got my 16g installed
DannyD
258
Aug 24, 2002
Fort Collins, Colorado
The last 20 days my car was inactive, because I was getting my 16g installed. It took 20 days because my o2 sensor was stuck into the o2 housing, and I had to get a slim line fan because my radiator was pushed back due to a front end accident, but it is finally done (thanks to the awesome guys at turbogarage.com). At this time, I also got dejontool upper i/c pipes, denso 190 fuel pump, and the exhaust manifold, o2 housing, and the turbo porting
My Impressions.
I have not been able to set up my HKS EVC IV for the new turbo, but right now I am boosting only 10psi with no creep. All I can say is that at 10psi my car is faster than the t25 at 15-16psi. I can't wait to turn up the boost.
I would like to thank the guys at turbo garage for the install, the dejon upper i/c pipes, letting me buy your slim fan and evrything else. An A+
And last, I have one question, how much boost do you think i will be able to run with the denso fuel pump and the stock injectors, I am thinking around 14-15psi until I get injectors and a intercooler. I think that is it.
Really? My S16g didn't really feel that much stronger at 13psi than 16psi on my T25.
Could this be because i also got upper i/c pipes, and the port work?
What I like the most about the 16g is that it keeps pulling after 5k rpms
Did you buy a big 16g or is it small? if so then the 50 or so extra cfms could be that difference hes talking about.
Andrew
A small 16G is pretty efficient at 15psi ( 505cfm's ). My question is do you have any porting and/or 34mm flapper door mod? I would like to just buy the small 16G with no work on it, but want precise boost control ( as precise as internals can do ).
The T25 flows 250cfm's at 15psi, so 15psi on the small 16G is a huge difference. Power is in tuning though, so a good set of 550s, a datalogger and a S-AFC and you should be good to go.
ya i have a datalogger and an s-afc, just need some 550s.
My 16g is ported, but i do not have have the 34mm wastegate flapper mod. I would suggest getting it ported, from what I heard it helps in the long run.
I have a ported small 16g with regular wastegate flapper. Pretty much the same turbo as yours. It probably is a lot faster, but I don't remember how fast it used to be anymore. I think I got too used to it to notice its even fast or not.
i still cant decide if a 50 Trim is too much boost for me. Since this is my ONLY form of transportation to work and college. A EVO 16G is still in the back of my mind. I dont know if i should risk getting a big turbo:confused:
I was in the same boat, but the 16g was definatley cheaper, and since I am a poor college student, and besides I can always go bigger when I finish college or find a better paying job...
What did you do about creep? I just bought a 2g w/ a b16g that supposely has huge creep. I don't know that for sure though cause I gotta change the hg on it. I'm trying to find ways of fixing it.
=Jason-
I just got my turbo ported and I dont have creep. I don't know if I would have had creep without the porting because it was never in my car unported
