Just finished running some logs!!!
DaOnE51T
88
Jan 17, 2004
Queens, New York
OK, just got done running some logs. I ran 50/50 mix of 93 and 110 octane.
First log @ 15psi
Code:
03/05/2005 19:18:04			26°	213.1°F	139.6%	139.6%	139.6%	112.3%	-17.9°F	0.18V	14.2V	14.17psi	88	52.2%	534.7Hz	0.0%	2813	0	10.50ms	31	43.5°F	3.49V
03/05/2005 19:18:05			18°	213.1°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.2V	14.17psi	101	100.0%	748.5Hz	0.0%	2938	0	16.64ms	52	43.5°F	3.49V
03/05/2005 19:18:05			14°	209.8°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.90V	14.1V	14.17psi	101	100.0%	1012.7Hz	0.0%	3219	0	18.69ms	64	43.5°F	3.49V
03/05/2005 19:18:06			14°	209.8°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.90V	14.1V	14.17psi	101	100.0%	1012.7Hz	0.0%	3438	1	18.18ms	66	43.5°F	3.49V
03/05/2005 19:18:06			15°	209.8°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.90V	14.1V	14.17psi	101	100.0%	1119.6Hz	0.0%	3656	0	18.43ms	72	43.5°F	3.49V
03/05/2005 19:18:07			17°	209.8°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.90V	14.1V	14.17psi	101	100.0%	1264.3Hz	0.0%	3875	0	19.46ms	80	43.5°F	3.49V
03/05/2005 19:18:07			18°	209.8°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.1V	14.17psi	101	100.0%	1377.5Hz	0.0%	4094	0	20.22ms	88	43.5°F	3.49V
03/05/2005 19:18:08			18°	209.8°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.1V	14.17psi	101	100.0%	1503.3Hz	0.0%	4375	0	22.02ms	102	43.5°F	3.49V
03/05/2005 19:18:08			18°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.0V	14.17psi	101	100.0%	1604.0Hz	0.0%	4625	0	22.78ms	112	43.5°F	3.49V
03/05/2005 19:18:09			18°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.0V	14.17psi	101	100.0%	1604.0Hz	0.0%	4813	0	23.04ms	118	43.5°F	3.49V
03/05/2005 19:18:09			19°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.0V	14.17psi	101	100.0%	1604.0Hz	0.0%	5031	0	23.04ms	123	43.5°F	3.49V
03/05/2005 19:18:10			20°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.49V	14.3V	14.17psi	87	10.2%	188.7Hz	0.0%	4750	0	1.28ms	6	44.3°F	3.49V
03/05/2005 19:18:10			44°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.3V	14.17psi	59	10.2%	56.6Hz	0.0%	3969	0	1.28ms	5	44.3°F	3.49V
03/05/2005 19:18:10			40°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.29V	14.3V	14.17psi	32	10.2%	50.3Hz	0.0%	3563	0	1.28ms	4	44.3°F	3.49V
03/05/2005 19:18:11			40°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.20V	14.3V	14.17psi	27	10.2%	50.3Hz	0.0%	3188	0	1.28ms	4	44.3°F	3.49V
03/05/2005 19:18:11			39°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.06V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	3000	0	1.28ms	4	44.3°F	3.49V
03/05/2005 19:18:12			39°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.02V	14.3V	14.17psi	27	10.2%	50.3Hz	0.0%	2719	0	1.28ms	3	44.3°F	3.49V
03/05/2005 19:18:12			38°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	56.6Hz	0.0%	2500	0	1.28ms	3	44.3°F	3.49V
03/05/2005 19:18:13			38°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	2313	0	1.28ms	3	44.3°F	3.49V
03/05/2005 19:18:13			38°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	2156	0	1.28ms	2	44.3°F	3.49V
03/05/2005 19:18:13			37°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1906	0	1.54ms	3	44.3°F	3.49V
03/05/2005 19:18:14			32°	203.0°F	139.6%	139.6%	139.6%	109.2%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1625	0	1.79ms	3	44.3°F	3.49V
03/05/2005 19:18:14			27°	203.0°F	139.6%	139.6%	139.6%	124.0%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1563	0	1.79ms	2	44.3°F	3.49V
03/05/2005 19:18:14			25°	203.0°F	139.6%	139.6%	139.6%	137.3%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1469	0	2.05ms	3	44.3°F	3.49V
03/05/2005 19:18:15			23°	203.0°F	139.6%	139.6%	139.6%	148.2%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1406	0	2.05ms	3	44.3°F	3.49V
03/05/2005 19:18:15			21°	203.0°F	139.6%	139.6%	139.6%	160.7%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1406	0	2.05ms	3	44.3°F	3.49V
03/05/2005 19:18:16			22°	203.0°F	139.6%	139.6%	139.6%	166.9%	-17.9°F	0.02V	14.4V	14.17psi	27	10.2%	50.3Hz	0.0%	1469	0	2.05ms	3	44.3°F	3.49V
Looked like everything was running good with the 15psi so I stepped it up to 19psi
Code:
03/05/2005 19:39:19			22°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	13.9V	14.31psi	101	77.6%	1000.1Hz	0.0%	3625	0	18.43ms	71	60.0°F	3.49V
03/05/2005 19:39:20			16°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	13.8V	14.31psi	101	92.9%	1151.1Hz	0.0%	3656	7	18.43ms	72	59.2°F	3.49V
03/05/2005 19:39:20			14°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	13.8V	14.31psi	101	97.6%	1295.7Hz	0.0%	3969	6	19.20ms	81	58.4°F	3.49V
03/05/2005 19:39:21			16°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	13.8V	14.31psi	101	97.6%	1446.7Hz	0.0%	4375	6	19.71ms	92	58.4°F	3.49V
03/05/2005 19:39:21			16°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	13.7V	14.31psi	101	97.6%	1585.1Hz	0.0%	4625	5	21.76ms	107	57.7°F	3.49V
03/05/2005 19:39:22			17°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	13.7V	14.31psi	101	98.0%	1604.0Hz	0.0%	4906	4	22.27ms	116	57.7°F	3.49V
03/05/2005 19:39:22			17°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	13.7V	14.31psi	101	97.6%	1604.0Hz	0.0%	5063	3	22.02ms	119	57.7°F	3.49V
03/05/2005 19:39:22			19°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	13.7V	14.31psi	101	97.6%	1604.0Hz	0.0%	5406	2	22.02ms	127	57.7°F	3.49V
03/05/2005 19:39:23			20°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	13.7V	14.31psi	101	97.6%	1604.0Hz	0.0%	5438	3	21.25ms	123	57.7°F	3.49V
03/05/2005 19:39:23			21°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	13.6V	14.31psi	101	97.6%	1604.0Hz	0.0%	5781	2	19.97ms	123	57.7°F	3.49V
03/05/2005 19:39:24			22°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	13.6V	14.31psi	101	98.0%	1604.0Hz	0.0%	6031	9	20.22ms	130	57.7°F	3.49V
03/05/2005 19:39:24			21°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	13.6V	14.31psi	101	98.0%	1604.0Hz	0.0%	5969	9	19.46ms	124	57.7°F	3.49V
03/05/2005 19:39:25			21°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	13.7V	14.31psi	101	98.0%	1604.0Hz	0.0%	6219	10	19.97ms	132	57.7°F	3.49V
03/05/2005 19:39:25			17°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	13.7V	14.31psi	101	98.0%	1604.0Hz	0.0%	6406	9	10.50ms	71	57.7°F	3.49V
Another one with 19psi
Code:
03/05/2005 23:04:26			18°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.1V	14.31psi	86	46.7%	1000.1Hz	0.0%	3406	0	17.66ms	64	44.3°F	3.49V
03/05/2005 23:04:26			16°	206.4°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.1V	14.31psi	97	69.4%	1138.5Hz	0.0%	3813	0	18.94ms	77	44.3°F	3.49V
03/05/2005 23:04:27			17°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.1V	14.31psi	101	86.3%	1339.8Hz	0.0%	4125	0	19.71ms	86	44.3°F	3.49V
03/05/2005 23:04:27			18°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	14.1V	14.31psi	101	92.2%	1453.0Hz	0.0%	4344	0	20.74ms	96	44.3°F	3.49V
03/05/2005 23:04:28			18°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.1V	14.31psi	101	96.5%	1559.9Hz	0.0%	4594	6	22.27ms	109	44.3°F	3.49V
03/05/2005 23:04:28			16°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.88V	14.0V	14.31psi	101	98.8%	1604.0Hz	0.0%	4781	5	22.53ms	115	45.1°F	3.49V
03/05/2005 23:04:29			17°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	14.0V	14.31psi	101	98.8%	1604.0Hz	0.0%	5188	4	22.53ms	124	45.1°F	3.49V
03/05/2005 23:04:29			20°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	14.0V	14.31psi	101	98.8%	1604.0Hz	0.0%	5281	3	21.50ms	121	45.1°F	3.49V
03/05/2005 23:04:30			20°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	14.0V	14.31psi	101	98.8%	1604.0Hz	0.0%	5781	4	21.50ms	132	45.1°F	3.49V
03/05/2005 23:04:30			22°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.86V	14.0V	14.31psi	101	98.8%	1604.0Hz	0.0%	5750	3	20.99ms	128	45.1°F	3.49V
03/05/2005 23:04:31			22°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	99.6%	1604.0Hz	0.0%	5875	2	20.22ms	126	45.1°F	3.49V
03/05/2005 23:04:31			23°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	100.0%	1604.0Hz	0.0%	6188	7	20.48ms	135	45.1°F	3.49V
03/05/2005 23:04:31			20°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	100.0%	1604.0Hz	0.0%	6375	6	18.94ms	129	45.1°F	3.49V
03/05/2005 23:04:32			18°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	100.0%	1604.0Hz	0.0%	6563	5	19.20ms	134	45.1°F	3.49V
03/05/2005 23:04:32			18°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	100.0%	1604.0Hz	0.0%	6625	6	18.43ms	130	45.1°F	3.49V
03/05/2005 23:04:32			17°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	100.0%	1604.0Hz	0.0%	6719	5	18.43ms	132	45.1°F	3.49V
03/05/2005 23:04:33			18°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.84V	14.0V	14.31psi	101	100.0%	1604.0Hz	0.0%	6906	4	18.18ms	134	44.3°F	3.49V
03/05/2005 23:04:33			33°	203.0°F	139.6%	139.6%	139.6%	99.8%	-17.9°F	0.53V	14.3V	14.38psi	83	10.2%	151.0Hz	1.2%	5938	0	1.28ms	8	44.3°F	3.49V
What do you guys think?
THANKS :laser:
Try logging just RPM, Knock, timing, and o2v (or whatever you use to look at fuel). Seeing all those values makes it harder to figure out. LOL
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
