TrevorS
- 515
- 4
- Feb 10, 2009
Newark,
Delaware
I'm not pretending to know which plug is better for any given setup, but I am convinced as to which is better in my situation. Please understand my purpose is not to knock the NGK, but only to provide balance to what appears to me a one-sided discussion
I've been running Bosch Platinum Plus for the past year (previously my car was dead for several months thanks to a burned up ECU). I've been strongly advised to switch to NGK copper, and so I did that Friday. Here is my result for my car. I make no claim regarding anyone else's Eclipse. So please don't feel that in any way I'm attacking anyone else's personal choice of spark plug. However, it's clear to me, this isn't a "one size fits all" situation
. My car is a 1990 GSX with 125K miles.
I definitely agree the NGK BPR6ES plugs (.028 gap) run differently from the Bosch Platimum Plus 4018 (pregapped), which is especially interesting since I was running that same NGK before my ECU burned up December 2007. I swapped out the plugs and leads at that time wondering if something there was preventing the car from starting -- obviously it wasn't
! My purchase of the Bosch instead of NGK was just curiosity (platinum being supposedly longer life).
However, after six miles with the brand new NGKs installed, I yanked them, put the Bosch back in, and took the car out again on the same run. Net result, there's no way I'll return to the NGK plugs. My idle speed dropped, throttle sensitivity dropped, willingness to spool dropped, an overall sense of sluggishness and lethargy settled on the car like a lead blanket after my lively experience of the Bosch. When driving with the Bosch, I keep having to let back off the throttle a little because the car seems to want to go. With the NGK, the car definitely doesn't go any faster unless I give it more throttle (in comparison, it's like having underinflated tires).
Now, my Eclipse is a 125K 1990 GSX with stock injectors, turbo, MAF, FP, FPR, and ECU. Maybe for some cars and configurations the NGK's work better, but unless some problem develops with the Bosch, I'm satisfied the Platinum Plus are a huge upgrade over the NGK for sheer driving enjoyment.
Photo of the NGK after 6 miles:
Photo of the Bosch after 2K miles:
!I've been running Bosch Platinum Plus for the past year (previously my car was dead for several months thanks to a burned up ECU). I've been strongly advised to switch to NGK copper, and so I did that Friday. Here is my result for my car. I make no claim regarding anyone else's Eclipse. So please don't feel that in any way I'm attacking anyone else's personal choice of spark plug. However, it's clear to me, this isn't a "one size fits all" situation
. My car is a 1990 GSX with 125K miles.======================================================
! My purchase of the Bosch instead of NGK was just curiosity (platinum being supposedly longer life).However, after six miles with the brand new NGKs installed, I yanked them, put the Bosch back in, and took the car out again on the same run. Net result, there's no way I'll return to the NGK plugs. My idle speed dropped, throttle sensitivity dropped, willingness to spool dropped, an overall sense of sluggishness and lethargy settled on the car like a lead blanket after my lively experience of the Bosch. When driving with the Bosch, I keep having to let back off the throttle a little because the car seems to want to go. With the NGK, the car definitely doesn't go any faster unless I give it more throttle (in comparison, it's like having underinflated tires).
