jay racing alternator relocation
clipto
2,316
5
Oct 8, 2011
Portland, Oregon
Anyone know if the wires will reach back to connect to the alternator with the jay racing alternator relocation kit?
i had to extend my wiring. but thats in a 1g. not sure if 2g's run the wiring the same way mine came across the core support from the passenger side.
2g's wiring run across the center support by the radiator, and Im pretty certain that the wiring will not reach back behind the motor. If you ran wiring behind the motor instead of in front (which requires a bunch of rewiring) you could use the alt wiring without cutting into it, but you would just be better off lengthening the alt connector wiring instead of moving your entire harness, unless you want to do a complete tuck, which is what I did
