1ghaaaaaw
- 313
- 1
- Dec 7, 2007
puyallup,
Washington
hopefully either all the air gets out of the system or something else is a problem in betweenthe clutch master and slave. ive got all week to figure this problem out and hopefully have the problem fixed in time.
not that this is your problem but i figure i would tell you abou my clutch problem,, as like you i had hardly any clutch pressure and couldnt get my car to go into gear,, after i bleed the system with seems like two cans of brake fluid,, i looked into the clutch pedal assembly, making a small ajustment i still had no clutch pressure, so i looked further, if your familur with the pedal assembly the clutch pedal is attached to a long rod up top then travels to the right and bolts to a plate right above the gas pedal well where this rod bolts to the plate the rod is kinda beveled to fit the plate so it wont spin in the hole,, well in my case the beveled area stripped out a small amount. so when i pushed the clutch pedal the other plate wouldnt more for about an inch or so,, causing my throw in the in the pedal assembly to not give me full pedal movment, thus shorting my pressure,,, just something to think about.
), and 3) It'll be safer for us all crossing over the pass if something should go wrong.
