ive got an extra turbo layin around........
RotaryAE86
249
4
Feb 14, 2006
West Palm Beach, Florida
well i have this master power t04e sittin around and i was gonna use it on the 13b i have in my ae86 but ive decided to keep my HP #'s lower so i was thinking about doing up the talon a lil bit. i know the upgrades i need to do and this is my daily so would this t04e be too much for my car? car is 95 talon TSI AWD
part # 810007
http://www.masterpower.com.br/eng_frameset.htm
That is a full on T4, cold side and hot side. You will not spool that thing before 6000, and the air that thing will flow is way more than you can handle with your mods.
In short, yes. It is too much.
yeah i know about the mods i will have to do to support the snail (fuel pump, fpr,injectors, exh mani, fmic, ic piping, fuel mgmt, ext wastegate) so its probably not worth it for my daily?
Not sure what exact size of that turbo is but I am running a to4e t4 60trim and in third gear I get 25psi at just over 5k.Its not that bad once your in boost its all good.Plus im only a downshift away from boost.
Also mine is a .68ar exhaust side not sure of the ar on your turbo.
part # 810007
I don't see that part number on their website.
Maybe you should take both housings off and measure the wheels so that you'll know exactly what you have.
Judging by the description its a 61mm with a t04s compressor housing & .68a/r vband turbine housing and a turbine wheel thats smaller than the typical P-trim so it should probably spool around 4800-5000 and it should max out at 650hp.
810007 To4e Turbo Ex. High-performance To E.u.a
Acima De 1,5 Bar
Ex: To4 58 Rt: Ta 60,98 Monofluxo
Inlet T4
.68
Open .70
Volute
