its running
c_k06
132
Mar 10, 2009
clarksville, Indiana
so i finally got my eclipse running and it runs rough. the knock sensor wire pulled out so i have to replace it thats y i think it runs kind of rough. also i blew the alternator fuse so i replaced it and when i hooked the battery up again and as i did it was sparking and the fuse blew again. what could it be???
Check the connections on the alternator. Something may be hooked up incorrectly. Also make sure you are hooking up all the pos wires to the positive and the neg wires to the negative you may have a hot going to the neg side or vice versa.
if it was sparking that bad and blew a fuse that fast then there is probably a crossed wire somewher.
