Justin DuBois
DSM Wiseman
- 3,343
- 3,316
- Aug 15, 2019
Oakland,
California
For you inquisitive type, I’ve got this setup running well, but it needs some tweeks to get dialed in.
Check my vehicle for the specs - only difference here is the Big16G, factory airbox and a 2.5” cat are in place for emissions testing.
For emissions testing I opted to switch back to MAF mode, and started dialing in boost control and maf comp.
Boost control is set manually by the duty cycle table, I am trying to hold 15-16psi to redline. Error correction is off so the target psi table is ignored.
MAF comp - Its roughed in, too rich mostly. I’m trying to lean things out higher on the hz scale. I’ve never hit these parts of the hz scale before, so the flow from the e3 mods must be helping.
So, tell me what you see? What moves would you make next?
(log to be added)
(log to be added)
