Is this enough fuel on E85?
doesitonall4rs
325
9
Oct 26, 2005
cherry hill, New Jersey
I was searching for a thread on here that was posted not too long ago, about some guy that made some really good numbers on 1000s and a single walbro, I just cannot find it!
I'm just curious if the fuel I have on my car will support what I need. It has FIC 1050cc and a single walbro 255 (that I will be rewiring to get full 14volts) The car has a 54mm 8blade HX35 in a bolt on housing. I plan to run it at ~30psi,
If somebody has the thread bookmarked that I am talking about please let me know, I could not find it!
Depends on your injector duty cycle with those 1000's, but if its an e85 only car you might as well get bigger injectors. I would get minumum of 1250cc or bigger.
If your running dsmlink get 2150s I'm kicking myself for buying pte1000's i see 98% idc on 30psi hx40
DAMN! Just a few quick questions
How big is your HX40?
How much base fuel pressure are you running?
How many fuel pumps?
Whats you AFR?
I used to run this hx35 on my talon on pump and meth and I was getting about 53-55lbs/min at 30psi.
I also have 1000cc and a 255 maybe ill just run race gas till I can get bigger injectors and a double pumper.
Whats you AFR?
60mm 7 blade hx40
43.5 fuel pressure
One wally 255 not rewired
11.5afr
60mm 7 blade hx40
43.5 fuel pressure
11.5afr
You really should look into rewiring the pump! Don't know how it is on a 2G but every car I've rewired the pumps on you have to turn the base pressure down because that bi*** really starts to flow!
I should be fine with fuel, that 60mm HX40 flows A LOT more CFM than my tiny hx35!
From all your guys posts it appears that I should have enough fuel! I really don't think she will put down more than 500hp on a 54mm hx35!
Anybody else want to chime in feel free!
Thanks for all the help guys!
