Is this ported enough? Need opinions please
TurboDreamzGST
240
Dec 22, 2005
Howell, New Jersey
Ok so long story short, i had to remove my recently installed ebay EvoIII 16g to port out my wastegate opening where the flapper covers....I just want some opinions if you guys think this is ported enough before I go through the whole process of re-installing it. Id rather know now if it needs to be ported more so I can just do that before its already re-installed. Thanks guys!
Porting the inlet of the turbine housing is also a good idea to help control boost.
The turbine housings on knockoff 16G's are cast from an already-ported mold, so there's little porting that can be done to gain flow. However, to go along with what Pat's saying, you can port the inlet Forced Performance-style where you direct the airflow toward the wastegate hole to prevent excessive boost creep. You'll be making the inlet shaped like a "D" just until you reach the wastegate hole.
It's a little hard to tell in the pic, but this is what I'm talking about:
