Is this a T28?
ILoveMyTsi
56
Dec 5, 2007
Scottsbluff, Nebraska
I tried to put a picture in of the turbine wheel, but it didn't work. It has 9 blades. I read that means its a bigt28? The compressor housing does like kinda small to me in the second pictuere and looks different than in the first picture. Its on ebay, maybe I should pass. Seemed too good to be true.
That inlet looks way too big to be a t25.
Here's a picture of my old t25
Xsboost, thank you for your input also. I think it was a big t28, went for about 300.00 dollars, just didnt have that much doe. Thought I was going to get a really good deal, as it was only listed as a t28 and the bid was 150.00 till about 2 minutes till it was over LOL.
certainly looks like a T-28 to me. Here's my FP Big T-28. (outlet is modified... It used to be a T-25) The reason I say it looks like a T-28 is because of the amount of material around the inlet. If you look at xsboot's photo, you can see there is a beefy amount of material on the inlet (thickness) where as my photo and your photo looks like is as been bored out. And the fins on do not appear to be that of a T-25.
Like T-for-turbo said, the amount of material on the compressor inlet is too thin to be a T-25. Its definitely a T-28.
Here is a picture I took when I swapped out turbos last summer.. notice the difference in thickness on the two compressor inlets.
stock T-25 (left) vs FP Big-28 (right)
Thanks alot guys, I ended up letting that one go, but I found another that was blown and picked it up for way cheap and am going to rebuild it. i was told the seals went and it has shaft play both ways, is that a big deal? Hope not. Neither of the wheels have bent fins or anything. Was just too good of a deal to pass up. Comes with a 2g manifold I can port and use on my 1g also. I'll post some pictures when I get it.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
