is this a evo 16g?
Wrong..Stop giving out the wrong information..
14B
49178-01010
49178-01030
49178-01400
49178-01410
Small 16G
49178-01520
49178-05200
Big 16G
49178-01420
Evo I Big 16G
49178-01450
Evo II Big 16G
49178-01460
Evo III Big 16G
49178-01470
The 52 is stamped in with a circle so it sits lower than the other numbers. What part do I measure? Whats the specs? How much of an upgrade should I notice with the small 16g compared to the 14b?
Don't worry about measuring.It's a small 16g..
You should notice a little more turbo lag..It should spool around 3k, so a little after the 14b does..But on the pro side, the butt dyno should notice an slight increase in power....Even running wastegate pressure, you should notice a difference..
