jdunbar10
- 133
- 0
- Jan 30, 2007
edmonton,
AB, Canada
im throwing no CEL light but can you check codes if there is no light? and if so how?
A scan tool?
Just go to advance auto they will scan it for free
Most auto stores will have a tool that they can use to scan it for you.
with out driving it to a damn store, with out buying or borrowing or using a scan tool
can you check for codes on the car even if there is no CEL light on
Yes you can but I really doubt your going to get any codes out.
Follow the procedure in the VFAQ or http://www.dsmtuners.com/forums/art...out-scantool-cel-testing-1g-turbo-models.html
You can make sure your CEL light works by watching the cluster when you turn the ignition on, all the lights are turned on for bulb test and the CEL will then go off after five seconds.
If the bulb works and it's not on currently then it's not likely you have any active codes. I forget if the ECU also flashes out the stored codes as well as the active.
Making/getting a datalogger is a good idea.
