Is there a spacer for the DS driveshaft bracket to engine block?
SnowBird
527
Jul 9, 2006
Cleveland, Ohio/Tampa, Florida
Finally putting my car back together and it appears the outside bolt hole of bracket looks like it wants a spacer, or does some other part go in there?
Manual was no help, but I dont remember a spacer and never found one rolling around my floor. I just put a bunch of washers in there for now until I can get a definite answer
Thanks
The Steady Bearing Bracket needs a Spacer if the AC Compressor Bracket has been deleted - If you are shimming with Washers I'd be VERY sure to Shim the gap up tight & properly, you don't want that Steady Bearing improperly aligned - I'd use the special Bolts & some soft Loctite on those fasteners too - & WHATEVER you do DON'T wring those "Special Bolts" off in the MOTOR - it is a TOTAL biotch when you do... been there, bought the mini drill.
Thats right, Ive deleted my A/C since then. I tightened the washer side first and then tightened the side without it, seemed to be OK, Ill check tomorrow again just to make sure. Thanks Buck.
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
