Is my timing belt on correct
webconnect
499
Dec 22, 2007
San Antonio, Texas
I have balance shaft ELIMINTATED
I've already started it for my first start of my build. It started and idled fine. However something else went wrong with my transmission, so the most throttle I ever gave it was 8%. (until i pulled stoped it and pulled the engine.) At that level it didn't feel QUITE right. Although it could have been me just nervous.
take a bigger picture of the cam gears that includes all notches because the knotches facing eachother can line up even though you are a tooth off.
i may be wrong but that's a 6 bolt in the pics just posted and he has a 7 bolt witch the crank uses the little blip on the timing tensioner to align the crank. Not the blip on the oil pump. So ignore kaliskos post.
