Is my engine about to crank walk?
FastGS-T
295
8
Oct 20, 2005
Arab, Alabama
Ok about a month ago I was driving at about 35mph and heard a knocking in the engine, but it went away. And after other complications found I had a blown head gasket. Well after waiting for my parts and warm weather we got the cometic head gasket put on with arp studs. We cranked the car and it ran good. Took it out for a test drive and turned left into walmart and heard the same knocking even worse it was beating, then stopped, this happened to more times while turning left and onetime wiht the clutch in turning left from a stop..
Is the crank moving causing the knocking? If it was a rod wouldnt it be knocking all of the time?
The best way to know is to check you crank end play. To do this you need to measure the amount that the crank moves from front (of the engine not of the car) to back. The best thing to do however is to pull the oil pan and have a look see. Chances are pretty good you'll know if something is up as soon as you get the pan off. Good luck---Jon
well ive never messed witha bottom end, what would i be looking for? My crank pulley doesnt spin off center. and it WOULD move back and forth if i used my hands, and it did move enough to crack two different timing covers... but none the less the bottom end was knocking so loud it was scaring me i thought my exhaust was beating the ground
oil pressure is dead on. hasnt ever varied through this whole situation right where she supposed to be
i was pulling out onto the street and pushed the clutch in and the car went blurp and just died on me... and my idle is at 500rpms instead of 850 and wont idle. and still making the rod knocking noise during some left turns
Doesn't the above alone hint at very bad things happening to the bottom end? Does NOT sound good to me at all.
