Is it toast?
Oddiseeus
May 18, 2010
Tallahassee, Florida
Ok all. I can use tools and take stuff apart and put things back together but am no mechanic. Which is why I am coming here with the question.
My 95 TSI (stock 130,000 miles) lost power on the highway. It ran but had no power, felt like I lost a couple of cylinders. I took the spark plugs out to run a compression test and when I removed the outside passenger plug (plug 1 or plug 4?) It was swimming in oil.
What could that mean?
Thanks.
Check the oil and coolant first for mixing before you go getting the engine up to temp and running to dso a compression test. If they are mixed dont bother with the test.
What were your compression readings? Did you also do a vacuum test? Any water mix in with oil? Any smoke coming of the exhaust? If so what color? Idle engine, unplug spark plug wire one at a time (any changes?). Do the same for injectors. That's a quick test that can help you which system to isolate (engine mechanicals block or head, spark and fuel.
It was all over the plug. I haven't done a compression test yet. Gonna make the time later tonight.
Please explain, was the spark plug hole full of oil as you were taking it out, or was the oil on the bottom of the plug? If it was in the spark plug hole has oil its the spark plug tube seals. If its at the bottom of the plug either of those mentioned above.
If the oil is covering the electrode or side of the plug that faces the cylinders, I would think something internal. If the oil is covering the opposite side of the plug and the threading on the plug it's most likely your spark plug gaskets.
Good advice 
