randizzle420
- 250
- 25
- Sep 20, 2009
El Centro,
California
The motor is balanced wisco pistons 8.2-1 compression stock rod an crank arp main studs head studs and rod bolts 5 layer metal head gasket balance shaft eliminator kit 1g Cas sensor front mount intercooler with 2.5 in piping big 16g off a Galant vr4 fluidine radiator greedy turbo timer greedy electronic boost controller act 2600 6 puck clutch, straight pipe exhaust with high flow cat, shep stage 2 transmission, and a fuel pump rewire. What level could I turn the boost up to? I'm guessing it's a stock fuel pump. All these things were done before I bought the car. Should I be adding something else? I haven't really drove the car around as I just now got the car registered as getting this thing to pass smog took forever. I plan to do all the fluids the differentials, transmission, engine, coolant. Not sure if I'll need new spark plugs I'll have to ask the old owner and the timing belt. I assume he did all this while he had the motor out but I'll ask him just to make sure. What kind of hp can I get out this setup without destroying something or does it need to stay stock and add some more supporting mods.
