Is it bad to run on wastegate pressures?
Blu90GST
172
Sep 10, 2013
East Peoria, Illinois
I skipped my bcs when I did my vaccuum lines. I'm running all stock fuel system for a 5 speed with a 14b. I'm getting around 13-14 lbs of boost on the stock gauge (putting in a real gauge soon)
Yeah I was just wondering because I'm running stright from the j pipe to the wastegate
And another question that's not really related but it has me worried, I recently replaced my head and now my heater core hose coming from the back of the thermostat house was steaming. I plane on putting a new hose clamp on tomorrow but I was wondering if I should be worried about my headgasket not sealing and pushing compression into my coolant system. What are the odds of this?
I mean my headgasket not sealing correctly in the first place and pushing air into the cooling system
Did you properly burp the cooling system? Do a compresion test and see what your numbers look like. You could also do a cooling system leak test and see if it holds proper pressure, if you have a tester. I would try to do both of those test and see what you come up with before anything else.
How do you burp it?
and conpression check tomorrow
Take thermostat cap off, turn car on, let car run for 5/10 mins while every now and then turning heat off and on. Squeeze top and bottom radiator hoses to push air out of them. You will notice bubbling from the cap. Once the bubbles stop, or slow down quite a bit, you are good to go.
The BCS or an MBC can only raise boost not lower it so running at wastegate pressure is the lowest it will go, so it is safe.
You're fine thats how my gsx is set up with a mbc in the middle
That is completely different than running it at wastegate pressure.
the concept of skipping the bcs is the same though and thats what I was referring to, obviously it's not the same as running at wastegate pressure or nobody would own a MBC :sneaky:
