Resolved Is an early 92 a 6 bolt?
way2slow4g63
49
Nov 16, 2004
muskegon, Michigan
i belive my car is a six bolt cuz it is an early 92
if i had an early 92 or older turbo motor (which is 6 bolt i belive) would the turbo parts work on my 4g63? (planing on putting turbo parts on my n/t) (also the only reason i wonder is i will need the oil pan as well)
It shouldn't matter too much whether its a 6 or 7 bolt motor as whether or not the turbo parts will bolt up though there are a few parts where you might have a problem like the oil pan. The best way to check is to look at the oil pan by the timing cover. If it's flat its a 6 bolt. If it's curved it's a 7 bolt.
The build date sticker is on firewall. It'll tell you if its a 6 or 7 bolt, if its before April 1992, you got a 6-bolt.
Last time I looked on my old car sticker was on firewall.
