FlyTalon
- 0
- Jun 27, 2002
Do i need to run a BOV or recirculating valve in my car or could I just connect the two wit a piece a pipe?
). Ok normally, the air goes through the turbo, and into the IC and then the throttle body. Smooth flow, no resistance, its all good. But then, you shift! So, you let off the gas, and the throttle plate slams shut. Now, the compressor wheel (in the turbo) is still pushing that air really hard, but the air is hitting the throttle plate! This extreme force (15PSi or more of air being pushed into a "wall") sends a shock through the whole intake system, back to the compressor wheel. This is called compressor surge. Now if this happens a couple times its okay, but it will start to take its toll on the compressor wheel. SpeedFreak03 said:Yea, let me explain why (then you will understand and believe us). Ok normally, the air goes through the turbo, and into the IC and then the throttle body. Smooth flow, no resistance, its all good. But then, you shift! So, you let off the gas, and the throttle plate slams shut. Now, the compressor wheel (in the turbo) is still pushing that air really hard, but the air is hitting the throttle plate! This extreme force (15PSi or more of air being pushed into a "wall") sends a shock through the whole intake system, back to the compressor wheel. This is called compressor surge. Now if this happens a couple times its okay, but it will start to take its toll on the compressor wheel.
So the BOV comes into play. When you let off the gas, the throttle plate slams shut, but instead of that air getting backed up and have no place to go, the BOV sends it all out of the system. So the turbo is still pushing the same amount of air, but instead of it going into the engine, it is being vented out of the BOV. So nothing hits the throttle plate, so no compressor surge!
Ah... nearly.SpeedFreak03 said:So the BOV comes into play. When you let off the gas, the throttle plate slams shut, but instead of that air getting backed up and have no place to go, the BOV sends it all out of the system. So the turbo is still pushing the same amount of air, but instead of it going into the engine, it is being vented out of the BOV. So nothing hits the throttle plate, so no compressor surge!
jk. Anyway, a lot of turbo'ed hondas don't use BOVs, because they only run 6-8HP (because of their high-compression motors). 6-8PSi of air hitting a throttle plate won't hurt it as much as 11-12PSi (DSM).
prostreetdsmx1 said:you know this is a really interesting debate because signal, kei office and the D1 drift cars have no BOV. The D1 cars run whats called a v-mount intercooler setup, where as the radiator is angled back about 30degree's and the intercooler is mounted horizontally between the motor and the front end and the piping on the IC is less than 2ft. they run no BOV and what you hear on drift videos is the air sucking back into the compressor wheel. They claim that spool up is faster (ideal for drift cars) and it holds boost without having to worry about a BOV leak. now keep in mind a drift car running anything larger than a td0518g is quite rare so maybe its just something they can get away with, with the smaller turbo. We have setup a few of these competition cars that we run and i will say the turbo is quite responsive and the turbo's seem to be holding up. We'll see how they end up in the long run.
just food for thought.....
boostedinaz said:I dont see how the position of the IC will affect if the car needs a BOV or not. Perhaps a better explanation of this setup would be ideal.
Why not just run a BOV setup like our cars??? They have the ability to relieve pressure and when the shift is made it purges the air into the compressor to help spool up. The best of both worlds. As far as spool up, I dont see how not having a BOV would help. As long as the BOV wasnt open the turbo should spool just the same. With no BOV there is no way to route the air back into the intake and keep the wheel spinning, so in theory it should slow the wheel down when that air crashes into it.
Perhaps pics or a detailed explanation is in order.
Michael
prostreetdsmx1 said:I didnt say that it is a better way to go, from what i was told by the Signal Rep is that the reason for no BOV is because boost is retained better because the "hotpipe" as they call it (uicp to us) is still charged so when they get on it after shifting its like instantanious boost add to that the fact that piping is less than 12" and you have a spool up that is unbeatable!!!!!!!!! Also in drift events there is very little shiftin but alot of on and off of the throttle, instant boost is key for drifting which is also why they run small high spooling turbo's, for example on the car we compete with is powered by a SR20DET and spools a Ball Bearing t-28 and hits full spool at 2700 (17psi). Many japanese companies seem to feel the same way because there are like 3-4 kits out there in the same setup. Hope this helps to understand better. We are currently testing a similar setup we made on a 240 and we are waiting to see how it does, i'll keep you updated on any progress.
jt1583 said:I think hes saying that when you let off the gas and the bov opens the pressure inside the intake is going to be close to atmospheric ( less boost). but with no bov the pressure in the intake is normal boosting level if not higher due to the closed throttle plate. so when you get back on the gas and open the throttle that compressed air in the intake is ready to go into the engine and you dont need to wait to spool again. this seems like it would cause quicker spool up other than the air hitting the compressor factor. but if these d1 drifters are doing it then it must be atleast an idea to look into.
i will say it spools amazingly fast and in the 2 months we have had it on the car we have seen not 1 negative result.prostreetdsmx1 said:thats the basic principle. i wouldnt say that just because they do it makes it right, i am simply sayin what is used in that market and what is used by the top dogs, on ours, we have it plumbed almost exactly like the signal kit so we are waiting to see how it worksi will say it spools amazingly fast and in the 2 months we have had it on the car we have seen not 1 negative result.
paranoidTSi said:Well I know the Neon SRT4s do not have a blow off valve as far as I was told. I don't think its needed in some cars, but since ours comes stock with one I would recommend it. I don't think you are going to gain much performance taking out a blow off valve, just quicker turbo death. I think the Turbo life is more important than a little bit of performance.
