Intermittent loss of power, misfire during boost
Spoolin92GSX
491
4
Oct 4, 2011
Inland Empire, California
Posting here because it doesn't really fit anywhere else, mods move if you feel appropriate. So here's the deal, I picked up this 97 GST a couple months ago and have been rehabilitating it since then. All boost/intake leaks have been eliminated except for a very small leak at one injector. Plugs have been replaced+gapped, stock fuel system, no tune, MHI 14b with an "aftermarket" adjustable WGA.
What's happening is, once the car is at operating temp I can feel a subtle loss of power/misfire start under normal driving conditions. When this happens, I am able to build boost up to ~13psi but with heavy misfiring (akin to boost leaking) and no power. Now, when I don't feel the cruising misfire, I can stand on the accelerator and it will struggle to build even 5psi of boost, but the engine will remain smooth.
I'm trying to get an idea of what could be causing this before I go diagnosing in the wrong areas, anyone have an idea of where to start?
Leaky Wastegate??? My actuator went out and I had some similar issues. Just throwing it out there. Just check it and then check it off the "list". :)
