soldave
- 737
- 1
- Feb 17, 2008
Okinawa, Japan,
Asia
OK, so I've now got a fully filled mission which isn't leaking, filled with Redline 75W90. Also have got a transfer case filled with Heavyweight Shockproof.
In the past few weeks (possibly since the Heavyweight Shockproof fill, but not 100% sure). I've noticed an intermittent noise from the front when I make slow (1st gear) left hand turns. At first I thought it was a tyre hitting some part of the splashguards but they look like they have enough clearance. Also, some times it feels like a knocking. I can't hear the tyres slipping or locking up or anything, but it's that kind of feeling.
Is it a consequence of the Heavyweight Shockproof, or something wrong with the transfer case/mission/front axles, do you think? Am a bit stumped on things to try to narrow down the problem.
Should also add I've lifted both wheels and done the 12 o'clock/6 o'clock and 3 o'clock/9 o'clock wheel tests and the wheel seems solid. It also only seems to be happening when I have my foot on the gas (i.e. not when it's coasting) and usually goes away after 3 clunks or so.
I did notice both lower balljoint boots are busted (one is cracked with no grease in, the other is leaking grease). They'll be replaced ASAP, but I can't really see that being my problem turning.
