1G Interior Panel and HVAC foam
Barra
7
Apr 4, 2003
Salem, Oregon
Is there a good replacement product out there for the interior panel foam? The stuff is on a lot of panels and also a lot of the HVAC parts to help seal and prevent rattling but it's all rotted out at this point. I've looked around for some adhesive backed open cell foam tape but what I've found seems to be pretty thick or too dense to allow for good panel fitment.
Picture for reference.
I picked up grey window sealer foam from tractor supply For my hvac under my dash. Might work for the rear hatch panels too, but you might want something skinner like i pictured in the second pic for the hatch panels.
I'm going to try this stuff, seems pretty close to the OEM.
This stuff worked really well. It is just slightly wider than the stock stuff which was actually a better fit and it adhered very well. The 17ft roll was enough to do all of the rear plastic . I didn't remove the side panels so there may be more spots but this will do for now.
