Interior/Dash lights not working
Frosted_Ankh
37
Mar 19, 2011
Saint Joseph, Missouri
My interior lights are working, like the dome and mirror lights kick panels all that, but my gauge cluster and my shifter light are not working. My side marker lights like abs door ajar all that stuff will come on. I just recently put the dash back in and changed the lights in the cluster to green leds (they work when i tested them out side the car) but when inside they do not come on the HVAC lights up and my dimmer switch works to dim it down. Also my left turn signal stays on even when i switch to the left. I do not have my hazard switch connected. Can any one help me with this please?
And before you say use the search bar i already have and could not find anything so please dont be a dick.
I suggest taking out whatever you had replaced, and make sure everything is still working. Check your door switches, fuses, check to see if something got pinched, and is shorting out. Or if the new lighting was installed correctly. Basically starting over, go slowly...and test as you go.
except they worked everywhere else and I know everything is plugged into the right spots. I know someone else had this problem but he said it was resolved but didn't tell how. I mean all other lights work gauges move but they don't light up unless directly hooked to battery. Also those lights work fine in other peoples cars from the thread leds in dash from www.superbrightleds.com
So I take it no one knows any way to help this. Or no one cares kind of a dick move.
my gauges also don't light up but everything else does. i did not put any led's or aftermarked gauges. they just stopped working. i changed my headlight switch and still nothing i checked all the fuses and still nothing. what did the other guy mean by check your DOOR SWITCHES?
