neuromonic
- 91
- 0
- Nov 1, 2003
Uhh, I know there is supposed to be all sorts of crud inside the intercooler. I was checking for boost leaks and decided that its very likely my intercooler hasn't been cleaned in the past 13 years so did it on a whim. I used simple green.
My intercooler had some sort of fiberous material inside of it. Like greasy cotton. I expected greasy oil snot, but wtf is this stuff from? I have a hard time believe it is an oil byproduct. And (if you can't tell from the picture) there is a lot of it.
At the very least it should motivate the rest of you's to clean your intercoolers.
edit: was showing the intercooler hairball twice.
WTF?? Now that yours is clean you should run much much better.
......i might be wrong.....but i do think that youve done a bad thing....the fiberous stuff is supposed to be in there im pretty sure, its part of it the intercooler,
