Black crud under valve cover
Afizzle
348
Jan 16, 2013
Dallas, Texas
Pulled the VC for powdercoating and upon re installation found this nasty black crud in the top of the head. there certainly has not been any performance issues or drivability issues so i do not think its causing a problem, im just curious as to what it is. it almost looks like the same stuff that will collect in your spark plug area after a looong time.
ARP lube from head studs? Can wash off the stud/nut from oil movement and deposit in low areas.
This would occur if you've (somewhat) recently put the head on with the aforementioned ARP hardware.
Just grab a flat head screwdriver and a shop vac :)
You should have seen the 1/2" thick crap hiding under the valve cover on my jeep... all the way across the inline 6. Simple 20 minute valve cover gasket change turned into 6 hours and two oil changes within 500 miles because i sea foamed it twice after I scraped what I could out.
Just dont "fling" the stuff around, I worked the screwdriver like a chisel and then vacuumed it out in small sections. ... but mine was 100x worse than that
