interchangeable downpipes
SPYD3R
82
Oct 25, 2005
Austin, Texas
Do the GS-T and the GSX use the same downpipe, or do I have to find a GSX downpipe?
Well I wrecked the GS-T and I have a GSX shell that has no exhaust at all and I am researching the parts to get the GSX in working condition.
1993eclipseGS said:
They are different. According to your profile you have a gst, Unless you are speaking about another car. You need a fwd dp if you have a fwd, And an awd dp if you have an awd.
Not necessarily true. I have a awd down pipe on my fwd eclipse. You can try to mount it you may need the converter also. I used my fwd converter and just had to have the flange on the converter end of the down pipe cut and turned to mount up.
There is a good deal of differnece between the AWD and FWD 2g. RRE has a picture of both which I have linked here:
AWD:
FWD:
I wish they had a side by side so you can easily tell if there is a length differnce as well. It "APPEARS" as if there is a few inchs added to the AWD version, but can not confirm this, since I really do not know. Sorry.
