intake manifold whistle?
Carmenpzito
94
Oct 18, 2005
Old Saybrook, Connecticut
I smacked a curb pretty good the other day (front end bounced nice and hard) and now when i drive in vacuum or boost there are two whistle type sounds coming from the center dash/firewall/intake manifold area. Looking at my boost gauge the vac @ idle is normal (around 18-19inHg) and while cruising @ 3200 rpm its like 24-25inHg. I hit max boost just fine (12psi). I checked my IC pipes and TB for rips or damage but everything looks normal. All vac lines are secure too. Not really sure what else to check?
Do a boost leak test, it will be the only way to determine where the leaking air is coming from.
