Intake manifold buildup
turbo_dsm
75
Nov 1, 2009
New Britain, Connecticut
My intake mani has some heavy buildup, is there anything that is causing this? i bought the car with a blown head gasket and fixed that. Any suggestions? thanks
Could be a bunch of things. Is the car running fine? I'm just concerned there isn't any build up elsewhere stealing performance from you.
The car idles bad but pulls pretty well for a stock turbo. I cleaned the Tb and about to put a new gasket since the old one was leaking. My ISC has to be replaced and it should run fine.. idk why there is so much buildup..
That build up is caused by the EGR system. That's carbon/oil and whatever else is in your cylinders coating the walls. The best thing to do is thoroughly clean it out with degreaser and remove the EGR valve.
So with that being said. Does it hurt your motor or performance to remove the EGR valve or what is the point of an EGR removal?
The purpose of the EGR valve is to recirculate the exhaust gasses when certain criteria are met. It is used to lower NOx (?) for emissions by adding in partially/burnt exhaust into the cylinders as an incombustible gas to fill the place of air. It will cool the cylinders a little bit and will re-burn the unburnt fuel in the exhaust mixture that got recirculated.
It will not affect your motor removing it other than allowing your intake manifold to stay clean.
You need the EGR for emissions and removal of the system will throw a CEL. People do it to clean up the bay, part of an emissions removal, better efficiency of the intake manifold or for all 3 reasons.
I've also read that its designed to give you better gas mileage. I removed mine and my gas mileage is the same though....
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
