Intake gasket choice??
relmer4
Feb 25, 2006
spokane, Washington
I did a boost leak test last weekend and found my intake gasket is blown. My question is...should I use Fel Pro, OEM, or ??. I have 20-23psi goals down the road, but I want to select a gasket that will survive. I would appreciate any insight you could throw my way.
The OEM one is a rubberized metal gasket which will hold boost better then the felpro paper gasket. I would get the OEM gasket.
Heat barrier gaskets are a great idea if you need to replace the gasket. I recommend them.
