Magnus Intake Gasket
ronnievermilion
42
Mar 22, 2008
vermilion, Ohio
I'm wanting to know if you should or should not use a regular paper gasket along with the Magnus Heat Barrier Gasket?
I took off my stock intake manifold and the paper gasket stayed intact with the head so should i scrap it off and only use the Magnus Gasket or is it ok to leave the stock gasket in place and put the Magnus Gasket over top of the old one? :confused:
Straight from the site:
"Magnus' heat barrier gasket replaces the stock gasket and forms a heat barrier between the intake manifold and the cylinder head. This dramatically reduces intake manifold temperatures. Best part about this gasket is that it is reusable! No additional sealant or gaskets are required. Tq to factory specs."
Magnus Motorsports » Blog Archive Magnus Heat Barrier Gasket |
