instrument panel problem
pur97tsifwd
331
Jan 31, 2006
Nevada, Missouri
Here is my problem maybe this has happened before my cars instrument panel is messed up. my oil and fuel gauge do not work my coolant gauge works but says hot all the time. and my turn signals work but on the cluster they don`t flash i have checked the bulbs. the abs and brake light flashes when i do my turn signals and also my high beam light is on but i am not on high beam but when i put my high beams on it goes away and it flickers every once in a while?
can anyone help me i tried a lot of stuff but cant figure it out?
Yes I have trouble reading that very long run-on sentence.
When I got my beater 95 GSX, the fuel gauge, coolant, and oil pressure all were flaky and problematic. I removed the cluster inspected it and it was mostly due to the add on indiglo face that were causing the needle to be obstructed. Make sure they are properly working. Also check the sender units/wires.
