instrument panel not working
awdtsi93
May 7, 2008
Phoenix, Arizona
HELP!!!here is my issue.. I've had this problem since I got the car the only thing that works on the instrument panel is the boost gauge and the oil pressure meter. The fuel gauge stays at about 1/4 and the rpm works up to about 4k, after that even if I punch it it doesnt go further up and the speedometer doesn't work at all. I've tried 3 different panels and still the same thing and no indiglos. the spinning needle behind the speedometer spins so the cable is good so im stuck any suggestions pleeaasssee
