mini zilo
- 783
- 19
- Jul 17, 2006
Chicago,
Illinois
I am installing an autometer c2 boost gauge, and I am to the point where i need to wire the light for the gauge. I am going off of the guide on vfaq which says "Remove your instrument cluster bezel. unplug the three switches, and move the bezel out of the way." I want to tap the wires at the dimmer switch. However, im not sure how to get the instrument panel off to get access to the dimmer switch... I could only remove the lower part below the steering wheel. I searched but could not find and answer, so hopefully someone can help... Also, since my guage has to wires...one for the 12v and one for the ground, what is a good place to ground?( I searched this as well but i found nothing, at least nothing i understood.
