installing big 16g
TRY MEH
Feb 18, 2013
Belleville, Michigan
i bought a godspeed FMIC and a big 16g turbo..
my car is a 1996 eclipse gsx 5 speed
7bolt 100% stock other than k&N and greddy BOV
i was wondering if everything swaps from my t25 to the 16g such as the oil lines and coolant lines
im installing this today any pointers how to do this would be nice!
im cutting my front bumper a little to make it fit
i will buy bigger injectors when i get the $$ for it but im going to run like 9psi until i can get a hold of a wideband A/F
You need a new oil feed line and a j-pipe if the godspeed fmic didn't come with one. You can slot the bolt holes on the return line so you can re-use it and bend the coolant lines to make them work.
No your gonna need an install kit.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
a kitt like this?
were would i just get oil feed line? on my turbo there is a strange fitting that comes off ill post a pic 1 momment
i have a j-pipe and all the connector's
