Installed the gutter guard grill... Pic...
jrider
121
Mar 31, 2003
Detroit, Michigan
Put the gutter guard (6 bucks and Lowes) on last weekend... I think it turned out pretty good. Look at that smile it gives now :).
sjgYFZ200 said:
Cool. How did you attatch it, with zip ties?
Yep... zip ties, and two screws on each side for the big piece in the middle. For the zip ties I just drilled tiny little holes to pull them through. It actually turned out nicer than I expected. I recommend anyone that likes the look to give it a try. It you're good with that sort of thing it should only take you a couple hours. It took me a little longer because I had to drill out the bolts for the brackets that hold the fog lights.
that's pretty nice, I went with a slightly larger size grill so I wouldn't suffocate the SMIC too much. Yours looks cool too though :thumb:
blcknspo0ln said:
looks OK.. i personally sprayed mine black when I installed my grill.
get an FMIC in her ASAP :shhh: :sneaky:
Me too. Black shows off my FMIC better than the silver.
Tallen said:
Kind of an out of style look IMO. You need a nice shiny FMIC up there instead.
In some places it is not wise to advertise.
Looks good to me :thumb:
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
