c5low13
- 40
- 0
- Aug 8, 2004
ellicott city,
Maryland
Hey...
Now what did I do?
I installed my magnus...before tryin to start the car, I also installed a new biss screw. Decided on installing a new one because prior to the magnus install...the car during idle would sometimes surge from 1k-1.5k...and when cruising then pushin the clutch in while still coasting to a stop...it would surge back and forth up to 1.5k then back to 800-900 then back to 1.5k, etc....
So, I had a shop check out the ISC a few weeks ago..they said it was fine...so I decided lets try the biss screw.
Well, Installed magnus, installed biss screw---also eliminated all emmission hoses.
When I go to start the car up...first started then died...did it again...started and died. Adjusted the screw(cant remember which way I turned it)....could have been the car just not have been started in a week....but eventually it turned on and stayed on. I waited for the car to heat up-It was idleing high...
Car got to norm opperating temps...did what the vfaq said for adjustin the biss screw correctly. Car was off...attached alligator clips from that connector to the ground on battery. The other ground on the port inside the car...is already grounded because of the 1g dsmlink cable being attached in there. K...So I start the car up...Car turns on and immediatley revs to 3k then goes straight down to 1k and idles there without a problem. Figured-wow got it right in the first shot. Turnd the car off...took out the clips. Took the car for a drive...well-was wrong!
The car without the connector grounded..still just idles at 3k rpm. Went back to adjust the biss screw with the alligator clips back in....no matter how much I scewed it in or out...it just continued to idle at 1k rpm....but as soon as you take the alligator clips off the connector and the ground...the idle shoots up to 3k.
So...im not sure whats goin on...
Another weird thing...I took out the relay for the pop-up headlights-so they dont popup.
The power output on my H4 silverstars seemed low and barely noticeable...even at night---but I figured prob just because of them not being in the up position.....
Well, when I grounded that connector for adjusting the biss screw...my lights got like 10x brighter...like how the silverstars should look....not how they were before.
So, I figured...if the car idles fine with that connector grounded...and my lights are bright as they should be....maybe I should leave that connector grounded always.
Took it out for a test drive like that...not goot...seemed a little slow to rev....and started hearing a poping noise coming from the rear of the vehicle...immediately pulled over and took out the alligator clips and the idle jumped right back up to 3k
Any help...is much appreciated!!
Now what did I do?
