Installed FMIC now I can't control my boost
noRys
Mar 30, 2005
D-Town, Iowa
Ok just installed my Buschur Street FMIC. Before I had my MBC connected from the wastegate to boost controller to stock j-pipe. The new j-pipe doesn't have the nipple where the boost controller is usually connected. Where should I connect this now to control my boost? Any help would be greatly appreciated.
Thanks
Ok, got the MBC hooked up now... I T into the BOV. Now I'm having problems with weird boost settings. Before the FMIC was installed, the MBC was set at 14 psi and boosted 14 in each gear. Now with the FMIC installed, I notice that in 1st and 2nd gear it's boosting at 14 psi and when in 3rd, 4th, and 5th it boost at 17-18 psi. Is this normal? Do you guys do 3rd gear pull to set your boost?
  • Wanted 6 bolt NT water pipe
    • chrisman287
