Installed a 6bolt, can't get electrical right, can't start it
b17tuner
232
Nov 9, 2003
Toledo, Ohio
With everything hooked up and ready to start. I get in and turn the key, everything works but when I hit the brake all power goes out, same with when I try and start the car. All dash lights just cut out and slowly come back. What is that?
Could a starter be wired incorrectly? I was just wondering because it seemed very simple 1 wire hook up. Maybe that's the problem.
ECU should be fine because it worked fine even when the alternator was shorted, I just left the charging wire off and the car would turn the starter over just fine.
Is it possible that I don't have the grounds right? Can anyone tell me where all the grounds are specifically supposed to go? I think the one from battery negative to starter bolt is wrong.
Thank you!
Thank you!
There should be 2 wires to the starter. One bolts on, the other clip;s to the metal clip coming off the solonoid.
Mike
Did you rewire anything or maybe had the starter dangling by the wires when the engine was out and a connection came loose?
The clip wire going to the starter solenoid is broken and coming off, I tried fixing the clip by crushing it a little to get it to hold but is there a better way to rewire it?
I have narrowed it down to the starter only. I pulled the starter out and ungrounded it and the car primed the fuel pump and everything, just obviously didn't have a starter to start. I have an extra good starter lying around so I will try that one tonight after work.
Thanks again!
Thanks again!
cut it off, strip just the end and put a new connector on and you should be good to go.:thumb:
Mike
Mike
I agree but remember soldering is always better than crimping, crimps will come off durring vibration, solder it if u have the means to.
-CB
Was the paint on the ground terminal I bought. I wasn't getting a good ground at all. That's what the weird short with the lights was. Thanks everyone!
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
