Chris95GST
- 224
- 0
- Aug 12, 2003
Ok, I just bought an Autometer Oil Pressure gauge (electronic) and an Oil temp gauge (electronic). Through doing a couple of quick searches on here I was able to find the pic of the 1g oil filter housing and was wondering if it is any differences on where to tap. Also since I need to tap it twice will this be a problem or are there two different screws/bolts I can remove? Also in the instructions it says to wire one wire to the ignition switch, which means and 12v source right and when it says engine ground that just means ground that wire right? Any more pictures or descriptions would be greatly apperciated. Thank you.
goodluck and hopefully you didn't buy a mechanical gauge. if not, then i'm sure you can tee from the same source AND the sensor or something
