Inspection
Wobet
345
Dec 25, 2010
Saint john, NB, Canada
Ok my eclipse is going to be getting inspected soon. But there are things I know for sure it needs and want to do myself
My front coilover sleeves and perches cracked because I don't have the bushings. (not my doing)
My setup is tokico illumina with ground control and eibach springs
Ground control agree to 20$ each replacement and 10$ for all the bushings. When I order this stuff and get it, is the install easy? (I will be getting a professional alignment during inspection)
Also around my head, I have noticed build up, and light oil leakage into my spark plugs. (this made it difficult to pop the wires out). Any advice on where I start there and how hefty the work may or may not be?
And last but not least, what else should I look for before inspection? There is no rust and no body issues. The car is super clean so I'm sure of it. And it drove nice until the crank pulley went.
might be needing a head gasket and as far as the ground control its a piece of cake so lopng as you have everything you need. best of luck
+ 1 one the suspension work.. its pretty simple... not sure about the head gasket.. might as simple as a valve cover gasket...
You must have a very thorough inspection where you're at. Most states in the U.S. just check basic stuff like lights, blinkers, mirrors, emissions, tint, etc. I'd just make sure all your lights are working and your check engine light isn't on.
Our inspection is super hard to pass to be honest. I hope it is simple work
Ok guys, I appreciate the relief your giving me on the suspension. I'm sure I can do that.
If it is valve cover gasket, is it as simple as ordering a new one, taking off the valve cover, taking out the old gasket, cleaning and installing the new one, then tourquing the cover to spec? Or is there compression involved?
Yes it is that simple. Just be very careful tightening the valve cover bolts as they are prone to stripping. Just get them a little over hand tight.
They won't come loose or anything? I'm starting to order these parts probably next week. So I'll have the car done probably the day I get it all or the day after
use a light coat of rtv (black or gray) on the gasket where it meets the head and around the spark plug tubes. Or it will leak.
A thin layer of Ultra Grey RTV is a very, very good idea. I always use RTV in addition to the gasket.
No it won't come lose. Just be very careful not to over tighten them.
I'll do that for sure then. Thanks
That abov is what we need for inspection here. It's not that bad but it can be tricky. I'm trying to figure out what coupling is
