Please Support RTM Racing
Inspection in NJ, with 6 bolt swap'd 2g?
kawboy
724
5
Jan 20, 2006
Toms River, New_Jersey
Would it be any harder to pass inspection in a 2g with a 6 bolt vs a non-swapped 2g?
You just have to make sure you keep all your emissions. Then you should be fine. It's illegal to back date an engine in a car out here, but the average tech isn't going to check to see if your car has a 6-bolt swap.
Hope that helps.
I took my 97 gsx to plainfield nj to have the car fail so i could get the 45 days and they ended up failing me for H.I.D`s because it eliminated the highbeams and a worn tire..
Mods were-
6 bolt
FP big 16g
greddy FMIC
apexi gt spec DP
apexi gt spec full exhaust (no cat )
550cc
255lph
lowered 2"
So if everything is done right no...Luckly i had awd so they couldnt do emissions....
heh, you should go up to the inspection in Fairlawn, NJ.
Not being racist but its employed with mostly black and spanish guys that are into cars, they passed me with a 3" exhuast with no cat or muffler, LOL.
Hey guys, I have a 99 GST that I can't get through inspection because my monitors are not staying in memory. Since I need 3 of 5 monitors I haven't found anywhere that will pass me. I'm not sure if I need a new ecu but the car is stock. I just need a sticker and don't even care if the VIN matches. Has anyone ever come across this problem or have any suggestions? I would greatly appreciate it, Thanks.
