Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
Hey, just like the title says, is the input shaft on the transmission (not fly wheel shaft) supposed to have some in and out play? The seal is holding the fluids back but im just curious because i get about a 1/8th inch of in and out play and i know my splines are starting to wear down a little. the flywheel shaft Has NO in out play. I pulled the trans to replace the TOB and clutch fork which i had thought to be making lots of noises when the clutch was not engaged, but when i press it in the sounds went away. when looking at the ACT TOB it didnt seem like it could be the main source of the noises, so i'm thinking it could be this input shaft rattling inside? i don't know. Let me know if the shaft play there is normal. thanks in advance!
Side note: the MT-90 in the trans came out the color of gun metal metallic BMW paint ... so obviously there is something going on in there, but i have not ground any gears during pulls or anything, just the occasional grind going into reverse. Im not really trying to disassemble the trans but will if necessary. i haven't ever disassembled a trans before.
also, if i DO have to take the trans apart, what are you guys using to seal the parts together? RTV? silicone? i think there is silicone on there right now, and does anyone know the torque specs for each piece of the tranny bolts just so i can get access to check out the gears?
ill take a video of how much play there is.. i actually think its the intermediate shaft that has the play, what ever the smaller one that stick out farther is that is off centered.
nice job Kyle
